In a nutshell, you need to install the loader valves BETWEEN the hydraulic pump and the tractor valves. That's what Charles did.
Rather than a T, just take a hose straight from the pressure line to the IN on your loader valves.
Now here's where it can get a little sticky. Does the loader have a "power beyond" type valve tree? You'll see three lines besides the ones that go to the lift and tilt cylinders. If you only have two lines, then you have a standard valve.
The plumbing is a little different from one to the other. On a standard valve, you redirect the hose that you wanted to Tee off into the loader valve IN, then run a hose from the loader valve OUT back to the tractor. Done.
With a power beyond, you run the OUT back into the hydraulic reservoir somewhere. The power beyond port gets run back to the tractor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
