Posted by charles todd on October 05, 2008 at 20:09:22 from (205.242.95.134):
In Reply to: cub wiring posted by L. McIlravy on October 05, 2008 at 19:30:03:
This is what I use, regardless of what type of tractor. Use 10ga on charging circuit from alt/gen to battery, use 12-14ga on lights, use 14ga on any other circuits to 15 amps. 16ga is good to 10 amps, but a little corrosion on a terminal lowers that value.
As for connections, I have two methods. Soldering is best, no substitue for quality soldering job. This is time consuming to solder each part. When I solder, I crimp first then solder the sta-kon terminals. The second method is to get some dielectric silicone grease and squirt some in EVERY fitting before you insert the wire and crimp. This helps drive away moisture and corrosion.
Anything less and you WILL revisit the wiring again, its just when. Personally I solder everything I can, use silicone grease and crimp the rest.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
