the main hitch pump is located in the lower left of the rearend just ahead of the left rear axle . My be something as simple as a sheared key on the pump drive gear .A new key a new lock nut one gskt . and a O/RING will fix that. You must drain the hyd, oil and to do this you will need the bottom third of a 55 gallon drum and it will darn near fill it . Now if this is not the problem you did not say if you have steering and breaks and if the tracor will or will not move if it has a T/A . Now if this is the case then the repair gets a little more involved as the tractor will have to be split at the bellhouseing and you will need a new pressure plate a PTO input shaft bearing seals and gskt and since you are replacing the pressure plate ya might as well reface the flywheel and put in a new clutch disc.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
