Posted by Bob M on September 30, 2008 at 06:19:56 from (151.190.254.108):
In Reply to: 1953 Super H Bolster posted by Gburns on September 29, 2008 at 19:00:10:
I recently rebushed the front end on my '53 SH. Here's a quick step by step:
1 - Jack the front end by jacking under the flywheel housing. (Block the rear wheels and crib the front end as required for your safety!)
2 - Remove the lower bolster/front wheel assembly. Note which bolster flange hole has the extended head stop bolt in it - this bolt MUST go back in the same hole at reassembly!
3 - Take off the steering pot cover and remove the castle nut from the bolster pivot shaft.
4 - Knock the bolster pivot shaft free from the worm gear and lower it out of the tractor. The gear is on a tapered spline - takes a good lick to break it free of the pivot shaft.
5 - Clean, inspect and lube the large thrust bearing (ball bearing) on the bottom of the pivot shaft.
6 - Knock out the old shaft seal and chisel out the upper and lower bushings.
7 - Install new bushings and seal. Then reassemble the front end. Recommend you pack the steering pot full with a good grade of grease - not gear oil as spec'd in the service book.
Note: New bushings completely eliminated the floppy steering on my SH!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
