Posted by Janicholson on September 29, 2008 at 20:42:41 from (66.188.163.79):
In Reply to: oil pump posted by smitty59 on September 29, 2008 at 17:26:31:
If it has a flathead engine (regular Cubs do, I am not positive about the Lowboy), The oil pump is built into the block as a part of the block casting. It is at the rear on the same side as the filter. The engine needs to be separated from the torque tube, and the flywheel removed to get to it. If it has lost prime, and has no oil pressure, Filling the system with a squirt type oilcan by attaching a hose to the hole in the block near the oil filter (allen head plug in it) then pumping in several oilcan loads of 40 wt engine oil, will usually get it primed and going. Start them often to keep them primed, maybe every two weeks minimum. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
