Posted by ScottyHOMEy on September 29, 2008 at 02:50:07 from (70.105.248.74):
In Reply to: Super A belt pulley posted by Jay Poole on September 29, 2008 at 02:33:39:
Are you talking about the actual belt pulley or a pulley mounted to the PTO shaft to drive the mower? You'll want to have that terminology correct if you go to order new seals, just in case they might be different for each application. (The belt pulley is oriented perpendicular to the long axis of the tractor, and the PTO is parallel to that axis.)
In either case, your parts book will show a single seal on either shaft. The new reality is that the shells of the seals now available are not as deep as the originals, and it is quite common to put two seals on those shafts, one over the other. This is sometimes also and effective cure for a spot in the shaft that might have been worn down far enough that a new seal on that same spot would still leak. If in using two seals you are able to get the seal surfaces on different, unworn spots on the shaft, you should get a good seal. Some folks go so far as to pack grease between the two seals. That might be overkill if you've got a good surface on the shaft to seal to, but falls into the "can't hurt, might help" category in my view.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
