If they were the adhesive mylar or cut vinyl, heat or chemicals will work. The old water-soak style decals are a little tougher, but crinkling them with heat is a good place to start.
A heat gun could get hot enough to bubble the paint even on the low setting if you get in too close or linger too long with it, but can work fine as long as you keep it moving and keep a distance, and stop as soon as the decal starts to release and curl up. A safer bet is to use a hand-held hair dryer on the high setting. It will take longer than a heat gun but won't get hot enough to hurt your paint. With either, the aim is to soften the adhesive underneath and cause some shrinkage to the decal itself (without actually melting it) to help separate it. Then you can clean up the adhesive by just wiping, though a solvent might be needed to get it all.
Which gets to the second method, which is to use a solvent that is sold as a bumper sticker remover. Most auto parts will hae something like that. It's the same idea but much gentler than gasket remover, which will eat paint. You might ask a used car dealer with a shop what they use to clean up cars for sale.
Any chemical or solvent, whether used as the primary way of getting someting off or just to clean up after using the heat method, you would want to test it on an obscure part of the tractor (the underside of the axle housing comes first to my mind) to make sure it won't harm the paint where you intend to use it.
Only other thought is that moving decals is something better done sooner rather than later, as red is a notorious color for fading and, if your tractor is out in the light a lot, you'll have a tell-tale darker area where a decal has been removed.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
