Posted by Janicholson on September 21, 2008 at 16:02:30 from (66.173.50.157):
In Reply to: Re: Early M runs hot posted by Eric Bergstrom on September 20, 2008 at 21:44:15:
The thermostat is in the bulging cast iron "blob" at the top radiator hose. It comes apart rather easily. New gaskets can be cut from NAPA .030" gasket paper by using a ballpeen hammer and tapping the gasket material gently all around the edges of the removed half of the casting (including the holes) the resulting gasket is perfect. Place the thermostat in a coffe can (or the like) and heat it on the stove. Use a candy thermometer to check the opening temp. If the water boils it is toast (in this case).
Other issues are gow much water will flow through the radiator and out the bottom hose (disconnected) if it is restricted, it will flow less than you can pour in the neck. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
