Posted by Centrall Illinois on September 20, 2008 at 14:26:52 from (75.105.128.58):
I have a 1939 F-20. I can get it to fire if I put some gasoline in the cylinders but it doesn't seem to want to pick up fuel from the carb. I have removed the priming cup tubes in the cylinder head and put plugs in their place. Replaced plugs, wires, and bought a rebuilt mag. I had the fuel tank cleaned out, cleaned out the fuel lines, replaced the sediment bowl assembly, and had the carburetor rebuilt. The carburetor idle screw is set at 1 1/2 turns, the load screw is at 1 3/4 turns. Turned the load screw to 2 and then 2 1/2 turns and it didn't seem to help. When I choke the carb and crank it over I eventually get a stream of gasoline out of the elbow. If I take it off of choke the stream quits. I am not thrilled about the stream of fuel but I have seen other Farmall carburetors do the same thing. I have the distillate manifold on the tractor. Is there a possibility my manifold could have an internal crack possibly to the exhaust side? If I have someone crank the tractor I can feel a suction on the carburetor. If I remove the plugs they are dry. Just curious what everyone opinions are? Thanks.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
