Posted by Rootsy on September 17, 2008 at 09:22:18 from (24.176.37.149):
In Reply to: M vibration posted by ckfarmall on September 16, 2008 at 15:37:49:
C-248 engine originally came equipped with cast iron pistons. Generally when replaced the new ones were Aluminum. If the engine is balanced for a heavier cast iron piston / rod assy then by going to an aluminum piston / rod assy will cause the rotating assembly to be out of balance. Generally at low rpm, such as these engines run, it isn't all that noticeable. Start pushing rpm up a bit, say the 1900 - 2000 rpm area and it becomes noticeable. My M w/ firecraters is exactly this way.
Over the years who knows what has been done to your engine. It very well might have a mixture of parts from bore to bore if maybe only one piston was replaced, etc. This would have a more adverse effect on harmonics within the engine.
An M is an internally balanced engine meaning that the balance is achieved via the crankshaft by removing or adding material to the crank throws to balance against the piston / rod assembly. There is no harmonic balancer on the front of the crank (unlike the majority of your car and truck engines) and flywheel balance is neutral.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
