Posted by Owen Aaland on September 15, 2008 at 17:23:21 from (65.161.86.22):
In Reply to: PTO Seasonal Disconnect. posted by Wayne from MN on September 15, 2008 at 09:15:58:
Wayne from MN said: (quoted from post at 09:15:58 09/15/08) That is a dry cavity; you have a seal leaking somewhere. Some (maybe a lot) dis-assembly required!!
It is a dry cavity only if there is no oil left in the transmission. :wink: The lower shaft in the clutch housing runs in oil all the way from the front to the rear. That is how the oil gets to the PTO gears and bearings in the front of the clutch housing.
There should be a blind hole the bolt to thread into. Most likely someone has installed too long a bolt at sometime and broken the the top off the hole exposing it to the oil reservoir.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
