KEB1 said: (quoted from post at 09:32:53 09/14/08) F-20's use bearing inserts like a modern engine, not babbitt bearings. I believe its possible to change them through the hand holes on the side of the engine, but if you do have a rod knock you might be better off to tear the engine all the way down & make sure there aren't any other problems.
What's the oil pressure look like? A rod will knock when the bearing wears enough to be loose, at which point you'll also have low oil pressure.
If you do decide to just change the rod bearings, check the crankshaft journals carefully for wear, and mic them to make sure someone hasn't had the crank turned & put in undersize bearings at some time in the past. These old slow turning engines are pretty forgiving, and if you're not using it to actually work you can get away with a lot of shortcuts.
I find it interesting that at a time when most automobiles still had flathead engines, babbitt bearings, and splash lubrication, agricultural engines had overhead valves, insert bearings and pressure lubrication.
Babbitt is a metal alloy similar to solder. Babbitt bearings are poured in place and then scraped by hand or bored to provide the proper clearance. Its an interesting process, but a real pain if you're not set up for doing it.
Keith
sure your not confusing the F-12's and 14's with a 20?? 12's and 14's used insert bearings with pressure where a 20 and 30 still used babbited bearings with splash lube. The W-40's were the only other engine before 39 to use insert and pressure sytems :wink:
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
