Posted by james Ashcraft on September 12, 2008 at 17:45:05 from (70.249.144.255):
In Reply to: Clutch operation of 686 posted by Owen Aaland on September 11, 2008 at 09:50:52:
LBSMJS said: (quoted from post at 12:06:51 09/12/08) Loosen the arm between the clutch shaft and the ta shaft.Get clutch free travel set.Then adjust the ta free travel to the correct distance by turning the slotted clevis.When that is done with the ta ahead & the clutch up adjust the arm that is slotted up against the clutch arm.I have had to sometimes take the arm off and grind the slot longer to get it right.
Update on the ta. I went out this afternoon and removed the inspection cover in front of the battery box to check the ta clutch and throw out bearing. What I found was the fingers almost wore off of the pressure plate. Thats why I was having trouble adjusting the ta. It appears the the throw out bearing wasn't adjusted properly or it is shot. I just don't really know not being able to inspect if more closely. Thanks for all your help.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
