If the engine will crank by shorting across the solenoid, you're not getting battery voltage to the solenoid when depressing the starter button. Your solenoid is probably feeding battery voltage to your key ignition switch should be 12 volts. When you press the starter button that should feed battery voltage to the S terminal on your solenoid and the engine should crank. You can use your volt meter to check for voltage on the S terminal when someone else pushes the starter button. Be careful when doing this. Have the brakes set and out of gear. Your are not getting battery voltage to your coil if the engine doesn't start when jumping across the solenoid. Check for battery voltage at the coil with your volt meter with the ignition switch in the on position. You may have a broken wire or not making good contact either from the key switch to the starter button or from the starter button to the S terminal on your solenoid. Hal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
