Posted by Owen Aaland on September 03, 2008 at 22:15:25 from (65.161.86.52):
In Reply to: 560 diesel posted by oldfarmer on September 03, 2008 at 15:26:19:
oldfarmer said: (quoted from post at 15:26:19 09/03/08) That is what I thought. That is why I changed the fuel filters. I am getting good flow to the pump.Could a partially blocked return line cause this problem. Maybe I need to check that
The RoosaMaster pump depends upon a pressure differential between the charge pump pressure and the case pressure to fill the high pressure pistons. A restriction in the fuel return system will cause a rise in case pressure and result in decreased fuel delivery to the injectors. The most common cause is the governor weight retainer crumbling and plugging the fitting on top of the pump. When the ring breaks up the resulting pieces look something like used coffee grounds.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
