Hi Michael, I saved several of Bernard le Mwchano's solutions for these tractors as my brother has four of them. Below is his reply for 3pt hitch problems:
3 pt will not go down:
Hi Butch, there is a cover on the right side,in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, may be the spring is unhook.
Hi, may be the unload valve is stuck. Check with engine running, raise the hitch and pull at same time the remote lever. If the 3pt hitch lifts, you have dirt in the unload valve. This valve is under the seat. Remove the large plug to access this valve. One trick, loosen the large plug for the unload valve 2 turns and start the engine, the hitch should lift if the valve is stuck. It has a small hole in the valve and just blow the dirt with air, replace with new O rings. Bernard le mécano Québec Canada
Micheal, I have the I&T shop service manual for 684, I could scan pages for hydraulics as 484 is the same. Send ne an email. I believe you have my email address.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
