On a 12 volt tractor YES you can EITHER use a full true 12 volt coil (NO Ballast required) or else a 6 volt coil with a voltage reducing (12 to 6) external series Ballast Resistor. A full true 12 volt coil dont require any ballast on a 12 volt system and has a priamry resistance in the neighborhood of 2.5 to 3.5 or so ohms. Theres nothing else required in the ignition priamry system wiring if its a 12 volt coil on a 12 volt system.
Yous sure the voltage reducing ballast resistor was wired correct in series with the coil after the switch and ahead of the coil??? If it were a good ballast (ohms around 1.5 to 2) and was wired correct it should have reduced the current and voltage on a 6 volt coil so it will work and not burn up???
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
