Posted by John T on August 12, 2008 at 16:41:50 from (66.244.97.31):
In Reply to: C charging posted by HENRY V1 on August 12, 2008 at 14:58:23:
If the battery is in decent shape that 10 amps may be allllllll she is supposed to charge at because the VR is doing its job??? Now, if after a long cranked start when the battery has been discharged Id expcet a higher amp charge for a while at least but then she ought to back down. What Im saying is if she charges at a higher (then 10 amps) rate right after start up and she keeps the battery charged it may be okay???
As far as other maintenance, you may wanna insure the VR has a good ground itslef and remove n clean n check the VR conenctions especially the wire from FLD on VR to the Gennys FLD post.
Thay made both 2 and 3 coil VR's but I have no specs as far as what IHC used. If the ground n VR connections are all good yet she never exceeds 10 amps despite a weak battery, the air gap and/or spring tension adjustments on the VR Field control relay may need adjusting. Still if she keeps the battery up I wouldnt be too worried just yet before you try to adjust the relay i.e. if shes not broke dont fix it. Jim or Bob M may have guidance as far as VR adjustments I dont have any.....
That jumpy ammeter may be cuz the gennys commutator is gunked up (try n clean it) or the mica insulatior segments need undercut or the brushes are worn down short or the brush hold down springys are sticking or else the VR's relay contacts are burned/carboned......
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
