Posted by Ted in NE on August 02, 2008 at 18:09:57 from (74.85.105.182):
In Reply to: TD9 injectors posted by FordsonMajorPat on August 02, 2008 at 05:08:33:
Pat
The hole I was refering to is in the plate below the nozzle valve you cleaned. Can get some carbon build up over time. Clean with a tip cleaner of the right size. Valve adjustment is very important. Also check for stuck starting valves while you have the valve cover off.Push down on the cup that goes over the valve & spring retainer make sure they are coming all the way up. Can free them up if needed by removeing the rocker arm assembly & cup over the valve. Use penetrateing oil & work them up & down. If to sticky remove the spark plugs. You can spray the valve stem through the plug hole. Usually will free up just takes patience. Quick check for stuck starting valves, crank over with change over lever on diesel. Will crank faster on cyl with stuck starting valve.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
