A Generator will work fine at EITHER Pos or Neg ground but if you convert to an alternator Id go with Neg ground as most all except for special made require Neg ground.....If youre re doing it Id go with Neg ground n be done with it....
If you change Polarity the ammeter leads need swapped or else it would register bass ackwards. If wired right with the tractor setting not running if you turn on lights or ignition it should swing over to - discharge...
The coil is also polarity sensitive. With Neg ground its lil + terminal ought to receive ignition switched input voltage while its other lil - terminal wires to the distributor.....
Mske sure the VR matches your ground as some are labeled for Pos ground while others are for Neg ground.....
BE SURE TO POLARIZE THE GENERATOR BEFOREEEEEEEE YOU START HER UP...
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
