Both transmission drive shaft & PTO drive seals are located behind the belly pump. Remove the pump drive shaft & the PTO seal is right there where the pump drive connector was located. Put the transmission in reverse & lock the brakes. Use a bar or pipe wrench to unscrew the drive lug, lefty-loosey. Remove the 3 cap screws & the housing comes off with seal attached. Replace the seal & gasket, replace the 3 cap screws, screw the drive lug in, righty-tighty, & you are done. Some oil will leak thru the bearing while you are replacing the seal. No need to tighten the drive lug much, it self tightens when the pump is used. Transmission drive is similar but you must remove the drive shaft coupler to get at the seal. Tip: when the nuts are off the tapered bolt, hold the coupler drive with a pipe wrench & turn the tapered bolt to loosen. Don’t try to drive it out or damage will happen.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
