With the TA lever back, does the tractor free wheel when slowing down? If so then you do not have hydraulic control to either clutch pack.
If you had the input shaft out of the clutch carriers, did the oil holes get lined up when the shaft was reassembled? Are the sealing rings in place on the input shaft? Did the jumper tubes get reinstalled?
Using a gasket as a pattern, I made a plate to bolt on the clutch housing with holes to be able to pressurize the jumper tubes to verify that the clutches are working. You can just apply air pressure to the high and low jumper tubes but be careful because the air pressure will blow them out. The plate just holds them in place for hands free operation.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
