Mechanical (blasting, knotted wire . . .) removal will obviously dull any galvanizing that might be left on them as it takes the yellow off. Chemical (oven cleaner or other strippers) will react with the surface enough that it might leave it clean but I wouldn't count on it being shiny when you're done. More likely, you'll have a varied, spotty finish that relates to the varying thickness of the yellow over the zinc.
If you're really intent on shiny galvanized, I'd try chemical removers first. Potential problem there is that the corrosives in the cleaner will show up any place where the zinc has worn or scratched through to the steel. If you were to get lucky and find the zinc pretty much intact, you could lacquer it to make it shiny and pick up the flaky look of the zinc. (It does look nice.)
Were it mine, I'd clean them up well and put the dull aluminum paint to them. The costlier alternative is to have the shop that will hot dip them clean them up and do the job.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
