If the block is OK they are not too bad to rebuild. The most critical area is the fit of the sleeves. These engines use dry sleeves that are held in place by friction. It is very important to have them installed to the correct height with the correct amount of installing force. Too little force required will result in a loose sleeve that will move and destroy itself. Too much installation pressure will distort the sleeve and cause tight spots. Add to this mix the fact that the block most likely has distorted some during use. Machine work on the block quickly adds to the cost of the overhaul.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
