The bolts in the clutch shaft couping are tapered and thus wedge into the holes. They are usually in there real tight, but I've always been able to break them loose (after the nuts are off) by using a box end wrench on the heads of the bolts and twisting. Better to use a 6 point wrench if you have one that fits. You may need to use a hammer on the wrench to jar the tapered shoulder bolts loose. You might as well order new rubber washers for the coupling as the ones in there are likely shot. Also the cup washers are also usually bad. You can't get the transmission input shaft out until you get that drive coupling out. Also, as I recall, you can't get one of the transmission shafts out without removing the brake cross shaft. I believe it is the counter shaft, but don't recall for sure. The manual says you can do it without removing that cross shaft by removing the snap retainer ring on the back bearing, but with all that's in the way, I don't see how that could be done.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
