You need to check for fire to the plugs, pull off one of the plug wires and hold it near a good ground or 1/4" away from the plug while someone makes an attempt to start the tractor. No fire from plug wire check for battery voltage to the coil. Should have voltage on both terminals with points open and switch on. Clean the points with some 320 wet or dry. If they're pitted replace them and condenser. If you have a ballast resistor installed between the switch & coil it may be defective.
If there's fire to the plugs you probably have a fuel problem with dirt or rust in the gas tank or gas line. Remove the gas line at the carburetor and see if there's a full stream of gas. Hold a clean container to catch the gas. A trickle isn't enough. If there's a full stream of gas check for a screen behind that tube fitting for a screen. It could be plugged with crud. Be careful not to damage that fitting. Hal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
