Posted by PaulW_NJ on July 09, 2008 at 20:16:05 from (72.76.239.189):
In Reply to: 240 weak hydraulics posted by Risner on July 09, 2008 at 18:48:58:
Risner said: (quoted from post at 18:48:58 07/09/08) Pulled screen and cleaned, no change. Put gauge on remote and have 1100psi at hi-idle. I noticed that pressure drops when valve is centered...shouldn't pressure hold steady???
I have both 240 and 340 utilities, and have had to rebuild the hydraulic systems on both tractors. You should be able to obtain 1500 psi operating pressure. First thing I would recommend is to locate the IH Blue Ribbon manuals on Hydraulics. You can find copies on eBay. It requires considerable work, but rebuilding the pressure control valve is your best investment of time if you want to use the tractor. There is an internal screen and orifice that are frequently clogged after 50 years of little or no attention, and the various Orings can easily be dried out, cracked, and broken. As mine were. There is a check valve that holds the pressure on the 3 pt hitch, and if it is bleeding down, that also can be rebuilt. Again, look for the Hydraulics, Valves and Systems manual on eBay.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
