Posted by BOBWA on July 08, 2008 at 06:35:30 from (216.46.133.14):
My Farmall "A" quit running.Through the process of elimination,I discovered there was no spark to the plugs from the magneto. Never had any trouble with the mag before and didn't know much about it.I did figure,though,it must have a coil and a set of points. Took it off and apart.Had the weird shaped,old coil tested.It was no good.The points were clean and working fine. They wanted $200.00 for new coil.DAAAAA!!! There MUST be a cheaper way.I'm always willing to try something once. My other tractor has a $20.00 coil hooked up to a distributor and points. Why can't I do the same. I threw away the old coil,attached an ordinary 12 volt coil to the nearby oil filter casing and wired it to the points in the mag.I also discovered to change the condensor to a $4.00 common 12 volt one.,,,runs better than it ever did! My question to you guys is this,,,,,,, Did I invent this proceedure or is it in the books as a common,less expensive way to replace a faulty coil in a magneto??? What do you think? BOB
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
