Posted by Bob Kerr on July 05, 2008 at 14:32:38 from (64.12.116.73):
In Reply to: 10-20 runs again posted by JDMAN60 on July 04, 2008 at 16:24:54:
Glad you gotther going! It was a great day when mine fired up after sitting 30-40 years. I am guessing you pull start it? If not be carefull if you are not sure where the spark is retarded and use the crank handle it may flip backwards. If I remember right look at the alum cap on the mag and when the rod hole is down all the way it is "off", to start it just has to be up a 1/4 inch from all the way down with the E4A mag. Don"t forget to flip the impulse lever on the mag or it will not have enough speed to make spark. If it has an F4 Mag it has automatic impulse coupler and will make a click sound when it sparks but it will still have to be retarded the same as the E4A to crank it by hand. If you have the choke on to run, it is either not getting enough fuel or too much air to run. Look for clogs in fuel line and carb or a loose or leaky manifold.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
