That is as easy of fix that you will ever do , First remove the steering wheel with a steering wheel puller and two 1/4 inch fine thread bolts that are at least 4 1/2 inchs long as it makes it easier with the long bolts . Clean out the holes in the wheel and chase with a 1/4 fine tap . Remove the nut that holds the wheel on install the puller and tighten it up and give it a rap with a hammer and it will pop off . Next remove the snap ring that holds the seal in then set the steering wheel back on the shaft and give a quick hard turn don't care what way you turn it and the seal will pop wright out clean up and install new seal replace snapring and put the steering wheel back on and go to work .
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
