Re: Bearing race out of wheel hub???
Posted by ScottyHOMEy on June 25, 2008 at 15:00:49 from (71.241.219.119):
In Reply to: Bearing race out of wheel hub??? posted by Sam F. on June 25, 2008 at 10:18:11:
The "inside" of the race is typically smaller diameter than the seat, so that it makes a lip. You should be able to take a punchchisel through one side to catch that lip on the back of the race on the other side. Just start tapping and moving the punch to four or five different points around the perimeter of the back of the race, and walk it out, moving your blows to keep it going reasonably straight. It might take what I call "smart blows", NOT wallops, the first time around, but once it starts evenly, it should walk right out. Like most jobs the second one will come out in one-quarter the time of the first, and in this case all the more so because once the first one is out, you most likely (not guaranteed, YMMV) will have more of an opening that will allow you to drive straight down on the second, instead of going in at an angle like you'll probably have to do with the first one.
Just get in there before you start with some kero or gas on a rag and clean off the back side of each one enough that you can distinguish the back of the race from the metal that it bottoms out on, so you'll know that you're tapping directly on the race. Shouldn't be difficult.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
