Assuming it has the band type IPTO,and the lever is not bent or linkage out of spec. There is a mark on the lever base (manual) that is midway from locked on, to locked off with the button on the handle. In this position, adjust the bands (seperately) (under the little peanut shaped cover on the top) until each is tight enough to prevent rotating the shaft by hand. Then loosten each about one half turn. This will (should) make it free to turn by hand. It should also make it drive, and brake correctly. Make sure you click the lever latch in either position. Running it W/O latching will cause slipping. Linkage slipping, and bent rods are also issues to wach for. Good luck. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
