Re: super c VR issues
Posted by mazemeister on June 20, 2008 at 09:44:57 from (24.188.81.230):
In Reply to: Re: super c VR issues posted by Bob M on June 20, 2008 at 07:48:12:
ok... latest update. it is a 6V battery. VR is a NAPA # VR-851. On the cutout relay- the "flicker" on shutdown before return to 0 is exactly as i've observed.
i opened up the VR and started the tractor. at mid-high rpms: if i connect a jumper wire between the 2 sides of the regulator relay (not the contact material themselves, but the metal parts), it pegs the ammeter- just like grounding the F terminal. So that tells me that the VR ground is fine. so remove that wire. the regulator relay looks like contacts are closed ie if i push on the relay, i can't feel any movement to close it. the cutout relay is open. if i push it closed manually, it stays, and the ammeter registers about 5-6V discharge. at low idle, if i manually close the cutout relay, it then opens on its own.
So based on how I understand the VR- it looks like maybe the VR relay contacts are resistive, which means the cutout relay doesn't see gen voltage so it doesn't close? but that woudn't explain staying closed at high rpms. i tried polishing the VR contacts a little, didn't help.
i tried running a second wire from FLD to F, that didn't help either. measured resistance of about .4 ohm across the original wire.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
