Posted by mkirsch on June 12, 2008 at 05:55:17 from (64.80.108.52):
In Reply to: M 2 way Hyraulic posted by tj in iowa on June 11, 2008 at 19:36:34:
Clean really doesn't tell you much. It could be clean but worn and not operating correctly.
What happens if you get off and operate the valve's lever manually, bypassing the rod? Does it feel the same in both directions, or does it snap, pop, or feel "mushy" in one direction?
When you hear that click, try to reconnect the hoses. You may not have them connected properly, or as you suspect, the connectors may be worn out.
To lower one-way cylinders with the two-way valve installed, you need to release the belly pump rod. That's normal.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
