Kidd, If I understand your post, youre still using the 6 volt genny correct?? I have used 6 volt gennys to charge at 12 volts simply by using a 12 volt Voltge Regulator and she worked NOTE Im NOT saying thats engineering correct or charged at any super high rate, ONLY that it worked although you could overheat the gennys field windings.
Next, you should have POLARIZED the Genny before you started the tractor if you changed battery polarity cuz you could damage the Voltage Regulator.
You need to decide what Polarity youre going to use,,,,,,,,,,,POLARIZE the genny (before starting),,,,,,,If you stay at the original polarity the ammeter should register correct buttttttttttt if you have switched polarity then you gotta swap ammeter leads as Bob suggested so it wont read bass ackwards.
If its a coil ignition the coil needs reversed if you change polarity. If at Pos ground the coils lil - gets ignition switch fed voltage while its other lil + wires to distributor but reverse that if at Neg ground.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
