Posted by Bob on June 10, 2008 at 15:14:30 from (69.178.228.68):
I answer a lot of posts on here about mags, and have worked on LOTS of them over the years, especially the H-4's.
I don't do it as often as I used to.
A customer had "dies when hot problems" with his "A", and I needed to put a coil in it.
I yanked off the cap, rotor was pointing straight up. GOOD ENOUGH. Easy enough to put the mag back on that way.
I took the mag with me, and proceeded with replacing the coil. As usual, the coil was STUCK on it's laminated "armature". I should have just sawed it off, but tried to press it out, "delaminating" the core!
Fortunately, I had a "donor" mag handy, and grabbed it's coil core.
Got the coil all in place, installed new points, and CAREFULLY set them to .013", using a dial indicator, rather than taking a chance on touching them with a feeler gauge with possible oil residue.
I took a look in the little rotor drive gearbox. Someone had set the gears up with the rotor one tooth retarded,so I corrected that.
I went to the customer's place today, and re-installed the mag.
Someone had previously installed the cap upside-down, and it was "cocked" a little, not sitting down on the locating pin, so I turned it 180º and swapped the sparkplug wires accordingly.
I had made a match-mark on the mag flange and mounting flange, so the timing was back where it was. I then tried to find the timing mark on the flywheel, to no avail.
Just to verify it was CLOSE, I started the tractor, which INSTANTLY fired up, and ran pretty well.
Shut it down, and tried AGAIN to find the timing matk on the flywheel. NO USE.
I pulled the #1 sparkplug, and used a length of wire to follow the piston travel, and find TDC.
THEN, I took another look for the timing mark, and there it was, the most faint line you could ever see. I marked it with a red paintpen, then proceeded to check the timing. The mag was tripping quite a bit AFTER TDC, so I reset it to trip JUST after TDC (in case they ever crank-start it).
Boy, does that little engine PURR now!
It's been rainy here, I hope the weather holds, as they plan to mow with it in the morning. I HOPE the new coil fixed the "dies when hot" problem!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
