Bert: As far as your ignition problem - I don't know. But, as far as the carburetor - if that carb is totally clean (every tiny passage) and the float level is "dead on" and working, then you have an air leak somewhere. HALF CHOKE = LEAN. It is either where the carb bolts to the manifold, or where the manifold bolts to the head. Crank the M and take it up to mid throttle. While it is running 'rough', spray some WD-40 around the manifold-to-head runners at the head. If it smooths out, you've got an air leak there and you will need to remove the intake and have it planed off smooth at an automotive machine shop, then re-attach it with a new manifold gasket. Or, you may have a cracked manifold. If so, replace. Torque to 70 lbs.
Do you have a gasket between the carb flange and the bottom of the manifold? A good gasket? That is where I would check next for an air leak.
After that, check valve lash. It should be .017" @ hot.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
