Posted by Tom Fleming on May 30, 2008 at 17:52:15 from (209.195.155.84):
In Reply to: Firing up an H posted by rnicholas on May 30, 2008 at 17:40:28:
well, first thing, is the engine stuck. If it is not, there are a number of things you may have to do. However, to get the first crack at it, fresh gas, drain and clean the fuel bowl, let gas run into carb, and then drain.
check and clean/replace plugs. check points. check oil. check coolant.
If there is oil and coolant, fresh gas, give it a try.
If these steps don't work, then you need to get into things like replacing points, condensor, possibly coil.
It all depends upon the condition the ingnition was in when parked, and how dry the shed was during the period it was in there.
I will tell you that I have started tractors that were NOT stuck, that sat in fields with a can on the exhaust with just cleaning fuel system and fresh plugs.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
