After several attempts to build good pressure in my '47 H by increasing the bypass spring tension, I finally found wear on the shaft just above the gear set. To remove the shaft for inspection, punch the pin out of the driver gear and pull the shaft out of the bottom of the housing. Shaft wear is easy to spot. I believe the service manual gives specs for the gear clearance and end play. If things are too worn, get another pump.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
