Your carb needs to be cleaned and the float adjusted properly. By cleaning I mean soak in in carb cleaner overnight and blow it out with compressed air. Otherwise your new parts will do no good. You have found the main jet. Max power is 5 turns out, will probably run with 3-3.5 out. The screw can be turned in if you do not need max power. Otherwise it is a "fixed" jet, and "adjustment" does not affect the way the engine runs unless you turn it in too far. The other 2 screws are idle mixture and idle speed. Look closely at them and you can tell which is which. The gaskets do not need any kind of sealer, more harm than good if the sealer gets in the carb. You could also have a governor problem or a leak in the intake manifold.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
