All firing order systems ON IH that I am aware of are radiator as #1. Then #3 then 4 then 2. Pull #1 plug, put your thumb in the hole and crank the engine by bumping the starter (ignition off). When you feel compression pressure, the #1 piston is moving toward TDC. Put a 8" piece of copper wire in the hole and turn the engine By hand with the fan belt and fan until the wire is almost at the top. The timing marks will now be almost aligned. Turn it until they are aligned. The dist rotor will now be pointing at a plug tower (assumes it was not moved) Put number one plug wire in that hole the next wire is Clockwise one tower and connects to #3. Then clockwise to #4, then the last one at #2. If it is out of itme, set the points to .020", then turn the distributor (while at TDC on #1) until the points just break. (use an ohm meter across them to ground, or a volt meter with the ignition on. to set the break point at TDC. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
