Ya have any of the old harness to work with???? If ya do then use my trick of building a new one . I use a 2foot by 8 foot piece of plywood and lay out the old harness on it and use finish nails to hook the old wires streched out and hook the ends over the nails . Then strip off the cover and see what color wire and size of wire and mark it on the board . IF it has and alt. i use a 10 Ga. for the main wire from the hot post of the alt. to the amp gauge then from the amp gauge to the starter . Then after i have all the layout work done i remove the old harness and start laying out the wires to each nail on the board . Myself i use uninsulated ends then i use a real good heat shrink over the ends or terminals to give the factory look . IF ya have wires that were broken off the org. harness then leave them long and finish them once on the tractor for the correct length . One trick that i do for a generator to alt. change over is i use a cv relay to energize the alt. and forget the ligthbulb or diode . As for the wire loom after years of tracing it down i found a wire supply house that i could get the factory style loom and with practce one can make a real factory look to it .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
