Posted by Andy Motteberg on May 14, 2008 at 22:34:02 from (4.143.217.30):
Hi all, I think I've done about everything on the 1944 Farmall H tractor to try and get it to stay running. I put oil in the cylinders today and did a compression check, Cylinder #1 has about 35, #2 Cylinder has about 65, and #3 and #4 have about 90. The valves were way out of adjustment so I set them correctly, same problem, still won't run. I cleaned the manifold, same problem. Me and Dad worked on the H a lot today and we can't get it fixed. We are guessing that the piston rings might be stuck, so I'll be replacing the piston rings next. I think this engine should have more compression because when we had the cylinder head off, we seen it has aluminum pistons and a high compression gas cylinder head.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
