Something like this happened to my M a couple months ago . It's all been rebuilt now . What happened was the pilot bearing failed and a roller fell out and got jammed into the teeth of the constant mesh gear and locked up the counter shaft to the input shaft . The main shaft would still turn so it was able to be towed in neutral . I'm not sure how the 450 tranny is put together but if it's similar to the M's then you might want to look inside to see what's up . It seems to me that if it was stuck in two gears it wouldn't move no matter what position the clutch was in . If you were able to move it with the clutch disengaged then it's not the gears . If it's like the M then the main shaft turns with the differential , the main shaft has all the sliding gears on it , with it in two gears you get no movement of the differential . That's if it's built like an M . Somebody will enlighten me and you about that . So , if it would only move with the clutch in you have a problem someplace else . Can't help with that . Good luck ! ...Randy
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
