MAGMAN said: (quoted from post at 17:23:02 04/28/08)
What is the correct way to adjust a pressure plate? on the tractor or tight on the fly wheel? on a flat surface?or what?
JON
The correct way to adjust the clutch is on a flat surface. They will be two adjustment measurements. One is the distance between the friction surface of the cast plate and the underside of the clutch cover at the mounting bolt holes. The other measurement is the distance between the friction surface of the cast plate and the levers at the point where the release bearing make contact. These dimensions are installed heights so you need some way to hold either the cover or the levers at the correct dimension while you make the adjustment to get the other dimension correct. It is one of the last steps the rebuilders do when remanufacturing a pressure plate assembly. These adjustments are made to very close specs, usually within a couple thousands of an inch. All the rebuilders I know of do not want any field adjustments made to their rebuilt units. If there is a problem they will exchange it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
