To start with your mobility problem starts with the MCV . Ya may have a bad pump maybe stuck valves in the MCV , blowen O/Ring and or Gskt's . To test one needs a JIC fitting that will go in the bottom plug hole in the MCV and a test gauge that can rear 600 lbs . Pressure should be over 200 i usualy set the pressures on a 706 at around 235-240 . Now as for the slow lift on the loader that comes from the rear pump , now if the draft control is botomed out then it will be slow try pulling it up and inch or so off the bottom . IF this has no affect then you will be time and money ahead to have the system flow rated by a pro with a flow rater . If that system is stock and has not been upgraded to a higher pressure relief or a larger GPM pump then the system should have 1750 lbs pressure at rated RPM and a flow of atleast 10 GPM.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
