Servicing the transmission and hydraulic system is a little different depending on if you have a front mount hydraulic pump for the loader.
Drain the hydraulic oil from the plug on the right rear of the hydraulic housing. That is where the seat is fastened. Remove the hose couple in the front of that housing to service the filter. The filter is a mess screen that is reusable. Refill the system through the plug that is on top of the housing in the right rear corner. Fill to the bottom of the fill opening, about three gallons.
The transmission is drained through three plugs on the bottom. The fill plug is near the transmission shift lever. The level check plug is on the side of the housing. It will hold about five gallons for a standard tractor, eight and a half for a low boy model.
If you have the front mounted pump, driven off the crankshaft, do not use the side plug to check the transmission fluid level. Instead you have to measure down six inches from the top of the fill opening. The front mounted pump draws the oil from the transmission instead of the hydraulic reservoir. The return oil from the front pump is returned to the hydraulic reservoir and then allowed to overflow back into the transmission so with the extra pump those oils are constantly being mixed.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
