I'm putting bearings in the M and tonight I was replacing the pto bearing and cleaning it up . From what I can see there are two different areas that could cause the problem , the bushing in the countershaft or the sleeve and after reading the post about the thick oil that could be it also . The sleeve just requires the oil be drained and the pto pulled , taken apart and cleaned . Turn the shaft with the tractor not running and the pto disengaged . It should feel snug but not tight with NO or very little fore or aft movement . The bushing might be a bigger problem . It's hard to get out with the countershaft on the bench so doing it two feet inside a hole six inches across might be difficult . I had to cut mine out with a hacksaw blade . Good luck ! ...Randy
Oh yeah It could be the shifter shaft is worn out too . That's also a oil drain and remove . In case you've never removed a pto on a H it's easy . This way will remove the whole housing . Find a piece of pipe that fits snug over the shaft about two feet long or a little longer for leverage , remove the oil in the rearend , remove the bolts holding the outer diameter of the housing , while counter balancing the shaft pull it out straight . Ya might have to twist it some to get it out of the bushing up front . If ya have to twist a lot you have a bushing problem . To remove the shaft from the housing remove the two bolts and the oil seal/bearing retainer . Then pull or bump the shaft out the hole you just opened up till the bearing is free of the housing a little ways and work it off the shifter lug . Then you can remove the sleeve . The rest is evident if you want to renew the bearing . Tap the new bearing on gently until the nut has full threads then use it to push the bearing on the rest of the way and tighten pretty good with a screwdriver in the cross drilled hole on the end of the shaft to hold it . add the washer and the jam nut and tighten very good and bend the washer back .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
