Does the TA work -- If you can separate the TA slippage from the clutch, put it in 2nd or third with the TA in low range let out the clutch and stand on the brakes. If the tractor slows as it should the "TA" is likely ok. Clutch replacement at a shop is likely several hundred dollars, TA replacement much more. Replacement TA alone (parts only) is about $600?? Remember that when either is installed, the Clutch and TA each must be adjusted. I'm not an expert on either.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
