Most likely, the transmission pinion shaft seal is leaking and has gotten oil on the brakes. Since the tractor is 50 years old, the brake linings are likely worn out too. Most likely you will not need to turn the drums. To get to the brake drums, you have to remove the final drives, so it's a fairly big job requiring lifting equipment or helper(s). There is nothing complicated here, but you should get yourself a parts manual and a shop manual. The main caution is support of the tractor while doing this. Due to the offset design, things can get unstable when the rear wheels are removed. Best to do one side at a time to minimize this problem. Also putting wedge blocks at the front axle so it can't pivot helps the stability problem. And while you are at it, replace the pinion shaft seals. You have to remove the brake drum from the pinion shaft to get to the one on the final drive side.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
